After install Aem Cai for 2 days, these engine lights popped up. Anyone know if this is serious issues. Should reinstall the stock Air intake? Or just reset the light?
Thank you
Thank you
...make sure to reset the codes as well...pull the battery cable while you're going over the CAI connections...will give the computer time to clear any existing codesThanks for the reply, I just double check on the Cai, and tighten everything again. Hope this will solve the issues.
Common trait and trade-off with virtually all aftermarket air intake systems; the straighter the intake pipe, the more pronounced the hiss-ss-ss.I just cleaned and resinstalled the Cai, now it made a hissing sound as turn off the engine, is that normal?I have run the OBD 2 test,and no codes.
Agreed. There is nothing like it. Takes me back to the days of my ‘91 integra hitting redline about 8k rpm or the older Si’s. Not the fastest cars but the sound and experience of those motors was intoxicating. With that said, this motor/trans combo is spectacular imo. A joy to put the pedal down.Thank everyone for inputs, especially PANDA for the knowledge. Turn out there is a leak at the cone filter connection to the pipe, i had to tighten with the ratchet instead of the flat head screw driver. Everything seem good now. gotta to love the V tech scream.
For some reason Borla and Magnaflow haven't make after market exhaust yet. I have been waiting a year now.
