Keep in mind the factory provided tow hooks are tie down points for transportation of the vehicle which are useable for tow trucks as well. They are not suited for the run and snap that is popular with much of the off-road community. So if relying on these have anyone connecting up to you do a gentle pull not a roll and snap.Inquiring minds want to know where the emergency tow hooks or tow points are on the Passport?
There are central jack points in the front and rear.
- There is an obvious front tow hook to the inside of the Front-Left wheel (photo 1).
- There is no tow hook or tow point for the rear (photo 2)?
- Rear center jack point is the black metal tab at the bottom of the rear frame member in photo 2.
- Front center jack point is the black metal tab below the white label at the bottom of the front frame member in photo 3.
Photos: 1) Front-Left Tow Hook, 2) Rear Frame Member with Center Jack Point, 3) Front Frame Member with Center Jack Point
View attachment 1473 View attachment 1475 View attachment 1477
