DIY- stainless steel metric bolt, nut and washer.
PS. Honda installs many a plastic cover to discourage regular folk from messing with them. This includes the front hood cover that hides access to the rad cap. Kinda silly.Yes I’m am. The plastic engine cover would have to be removed to gain access. This is just a quick connection, mainly for trickle charging or quick boosting in a pinch. I’ve have had the the air box and battery cover off. I’ve previously greased both the positive and negative connections as a preventative maintenance measure. It just so happens that the battery ground runs to the unibody frame among other locations including the block. As a licensed mechanic I’m confident that this will not harm my passport.
Looks great, and easy access.I'm using that same threaded screw hole, Sendbeta. Also I have installed a BatteyrMINDer Flush mount EZ connector. View attachment 5489 View attachment 5492 View attachment 5491
So now, I just pull up next to the trickle charger mounted on the garage wall and plug it in without raising the hood.
Do you remember what size bolt, length and thread pitch?DIY- stainless steel metric bolt, nut and washer.
hi, do you mind to take a pic of how you did the wiring and howdid you “tucked” in those wires? Is the ezconnect fits perfectly on the “opening vent “ off the base windshield?I'm using that same threaded screw hole, Sendbeta. Also I have installed a BatteyrMINDer Flush mount EZ connector. View attachment 5489 View attachment 5492 View attachment 5491
green = + pos hookup on battery and wire ty wrapped off; yellow = - neg hookup to car body/frame, a threaded hole; blue = trickle charger socket. I drilled a small hole thru the plastic housing to feed the wires from the socket. Wire crimps are need to lengthen the runs to the battery and ground.hi, do you mind to take a pic of how you did the wiring and howdid you “tucked” in those wires? Is the ezconnect fits perfectly on the “opening vent “ off the base windshield?
thanks in advance![]()
thank you Bayoubob, your set up is really good, I might do that in the future. I was in Costco and bought the battery tender (4.5amp) for $36.99 amd I thought it was a good price. and tried if it will worked on the bolts off the mounting bracket of the air filter box. And it seems it’s working fine. Made a video just for this🤦🏼♂️.green = + pos hookup on battery and wire ty wrapped off; yellow = - neg hookup to car body/frame, a threaded hole; blue = trickle charger socket. I drilled a small hole thru the plastic housing to feed the wires from the socket. Wire crimps are need to lengthen the runs to the battery and ground.
pic #2 showes the set up. You don't have to raised the hood to plug in the trickle/charger. View attachment 7575 View attachment 7576 I use pink flagging to remind me to unplug it when leaving out!
Finally added this bolt today after I finished replacing the air filter with a AEM filter. The bolt provides a good ground. I verified it with my meter. Great tip. ThanksFrom the Ridgeline forum
I did this today, thanks for sharing! One of the easiest hacks I think I have ever done!Finally added this bolt today after I finished replacing the air filter with a AEM filter. The bolt provides a good ground. I verified it with my meter. Great tip. Thanks
