ZEISS lens wipes...get it at WalmartLooks pretty good/I keep a swifter duster for the piano black for the dust and it works pretty well but fingerprints are my issue / I have used plast-dip on my Wrangler for outside only / how does the inside feel? tacky??? It was on my antenna and tacky but was fine on my spare - hope this makes sense
I’m going to try it out for sure/thanksZEISS lens wipes...get it at Walmart
Nice! This will be on my todo listI ended up buying all the grey trim pieces to replace the piano black trim, including the piece that runs along the whole dash. Much happier now, and I think it looks much better than having black everywhere. It also a nice addition to the grey seats... View attachment 1939
Where did you purchase the grey trim pieces?I ended up buying all the grey trim pieces to replace the piano black trim, including the piece that runs along the whole dash. Much happier now, and I think it looks much better than having black everywhere. It also a nice addition to the grey seats... View attachment 1939
I went ahead and bought all the trim pieces (including to the piece to the left of the steering wheel as well as the trim piece on the steering wheel) After I received them I decided not to install them and just stick to the piano black. I want to sell the whole set of all the gray trim pieces. Anyone here interested in buying? I have both pieces for the door panels, the center console cup holder/shifter piece, the main garnish piece across the dash, the small piece to the left of the steering wheel and the center garnish piece on the steering wheel. I would be shipping from Idaho.Where did you purchase the grey trim pieces?
I found it a lot easier to remove the wireless charger when you have the garnish piece from across the dashboard taken off, and unscrew the four screws from the console piece directly above the wireless charger (the piece with the usb, outlet and buttons for heating/cooling seats.) once unscrewed and lifted up you can reach back and lift up on the back of the wireless charger and it comes up much more easily.The doors are easy if you've had experience popping door panels off. The trim pieces are screwed in, so once you have the door panel off just unscrew the old and screw in the new one.
The center lower console was a PITA because of the wireless charger. You have to use a trim removal tool to force the wireless charger out from the back of it. Once you pop the wireless charger up, disconnect it and move it to the side. You will then see the two screws holding the back of the center console in place.
Here's a good video showing the removal of the main center piece:
Plasti-Dip. Had to figure out how to pull the wireless charger out, but once I got that pulled I was able to remove the 2 screws under it and pull the whole console out by lifting it up with a little force. The color is selenite gray.
How did you figure out how to remove all the trim without breaking it to replace it with the gray you bought?I got tired of all of the dust on the center console, so I got rid of the piano black. I'll probably remove more of the piano black once I figure out how to tear the dash apart: View attachment 1155
