1 - 8 of 8 Posts
Another seamless install albeit drivers door being a little fiddly getting the bubbles out. Instructions recommend to use 3M Protective tape application solution. I used good old Windex. It has served me well over the years when applying motorcycle decals.
Grille Automotive tire Automotive design Bumper Automotive exterior
· Premium Member
I installed the same. I, also, used Windex - works just fine.
This is on my agenda - not sure to do with the OEM or aftermarket
I do wish they were longer to cover more real estate
I purchased the generic Passport that dealer had on hand a time of purchase.
2023 TRAILSPORT SONIC GREY
I've seen these and paid attention recently getting in and out and my foot does not land here. It goes up higher on the plastic sill above this. Do you really bang this part up?
I'm careful on entry and exit to not hit the sill or plastic trim. But not everyone is. I bought a small roll of clear vinyl and installed on all 4 door sills. Posted images in the "what did you do" thread i think. Much cheaper than Honda sill protectors and stays color of car since they're clear
2022 PP Elite AWD
I'm the "dont care" type when entry/exit so I may borrow your idea. I may also cover much more than what's pictured since I'm sure I also have the same problem as @Bajapalm
EDIT:
I took the time to find @JArcher21 post about it. Scroll two posts down for the product they used.
Reactions: ballisticexchris
1 - 8 of 8 Posts
