The different tire size is due the the Touring and Elite have 8.5" wide wheels, the other trims have 8"Agreed, agreed, agreed.
I think Honda went overboard with the 20" wheels as a standard item. Honda is projecting the Passport as an 'off road' vehicle trying to imitate the Jeep products but failed by making the vehicle to look too 'sporty'. Honda's adds display the vehicle going thru mud, mountainous rocks, river streams, three feet of ice & snow, etc. I believe it is called 'cognitive dissonance' or just plain brain-farting.
I expect there to be a future thread subject devoted to advice & comment on how best to replace the 20' wheels & tires. Sad.
One consolation to keep in mind is that the standard tires are 245/50R20. but on the Touring and Elite models the tire size is 265/45R20.
I was going to say the same thing.Wtf is with you and a chick car
Depends upon Trim level and options. On the 2019 Jeep Grand Cherokee Limited 4 X 4, for instance, the standard tire size is a 265/60R18. A 20" wheel size is optional. I believe that even some trim levels have 17" wheels but I might be wrong.The different tire size is due the the Touring and Elite have 8.5" wide wheels, the other trims have 8"
Also, if you look at most trims of the grand cherokee the 20" wheel is standard...
I had just the opposite experience from my '17 CR-V (Bridgestone tires) to the PP. Far better ride, even though it's on the firm side. The CR-V was jarring and annoying. Felt every little bump.Thought this would be an improvement over CR-V. It's not.
A couple things to keep in mind, the struts/shocks and suspension bushings are still breaking in to a degree. Also as you get more miles and heat on the tires, the sidewalls will start to become a little more pliable.I'm worried my back is not enjoying the car as much as the rest of me. The suspension isn't noticeably jarring but it can build up on my back pain over the drive. I didn't really notice during the test drives but I'm hoping its also because I had a physical week. Still, have a small concern that it's a little too stiff of a ride for me in the Northeast Corridor. My old Ridgeline was nothing but comfortable but it had 17" rims and slightly bigger tires.
Thanks for the heads up. Got a little worried and literally just ran outside to check the tire pressure using an external gauge and got 38 PSI. My initial 44 PSI read was taken from the onboard TPMS sensors via gauge cluster after about 30 min of hwy driving. To which I'm guessing is a warmish reading vs cold.I believe the spec tag on the door jamb recommends 37psi for the Continental tires.
Were the tires at 37psi when cold? So far in a couple of weeks driving my new Passport, I'll see 39psi readings on the gauge cluster after highway driving.Thanks for the heads up. Got a little worried and literally just ran outside to check the tire pressure using an external gauge and got 38 PSI. My initial 44 PSI read was taken from the onboard TPMS sensors via gauge cluster after about 30 min of hwy driving. To which I'm guessing is a warmish reading vs cold.
I would say that my tires from factory are currently reading 37 PSI +/- 1 PSI cold and it's 50F outside at the moment.Were the tires at 37psi when cold? So far in a couple of weeks driving my new Passport, I'll see 39psi readings on the gauge cluster after highway driving.
Having 20" rims is what's known as having a pimped out ride. Taller the rim usually means less the rubber. Less the rubber equals less the shock absorption. Think mountain biking. Try riding a rough trail on a mountain bike with no suspension. Then try it on a fat bike with no suspension. You'll find the fat bike absorbs a ton of the trail shock. Same is true for comparing 20" rims and short tires versus 18 inch rims and tall tires. Of course the driver is going to get a better road feel through the steering wheel with 20" rims and they're going to notice less flex driving hard into corners. There are certain advantages for smooth surface driving. But on fluctuating roads with the common bumps and so- forth, and off road, the 18" rims are going to be preferred.
As I mentioned, I bought my Elite for the wife as it's an optimum chick vehicle for her. In summer I'll keep the 20's on and in the winter the car will be toughened up with 18's and BF Goodrich All Terrains. That's the plan at least. I want the lady to ride in comfort while in her glorified mall cruiser. But when winter hits, Old Inbred will put it through some tough-man paces while on ski trips when 18" of powder hits the ground.
