1 - 20 of 20 Posts
As with DIY Install of Rear Seat-Back Protectors, spoilers first with completed install for the Cargo Side Panel Protectors... 1) left side, looking rearward, 2) left side, looking forward, 3) right side, looking forward. A minor nuisance with the Honda Cargo Tray. There is sufficient clearance with the Honda Cargo Tray in place, but there will be interference when trying to open the storage cover with the Cargo Tray on top. Remove the cargo tray first and the storage cover will open without interference.
Vehicle Car Trunk Floor Tire
Vehicle Car Trunk Floor Family car
Vehicle Car Trunk Rim Floor
If you wish to attempt a DIY, the PDF attached below is the installation instructions for the 2019 Passport. It can also be found online from sellers of Honda OEM accessories. No need to repeat the instructions, but below are some tips. It is not difficult.
  • Unpack your order and be sure that you have all necessary parts and hardware for the install.
  • A work light will be helpful, especially for dark interiors.
  • A roll of wide masking tape will be more efficient.
  • A second drill helps to expedite the install. One for the pilot drill bit and one for the cutter or larger drill bit.
  • Have a vacuum for clean up.
  • The female snaps attached to the protectors have some adjustment/movement to it. You do not need to be precise, but it helps to center the female snaps before marking the holes for drilling.
  • Take your time with the placement of the protector and marking the holes for the first two snaps. That will dictate location of the other snaps.
  • If you are using a Rotabroach cutter, clean the cutter after cutting through the carpet layer. The carpet and masking tape clogs the cutter. 5 locations (on each side) are in the wheelwell with a carpet atop of flexible plastic. 3 locations (on each side) are hard plastic.
  • Follow the recommended order for drilling and installing each snap, because...
  • As you complete each hole and snap, leave the protector attached to each completed snap. The snaps takes a bit of patience to align and snap in place, especially on the flexible wheelwell. The protector is flexible enough to be folded over to drill and install the next snap.
Good luck.
View attachment 1629 View attachment 1631 View attachment 1633
Good luck.
Well done!
@DudeCS are this the little clips called rivets ? Or I’m missing them?
Had it for a week now and just open the box and didn’t see an baggie or anything loose.
The items you hold are the female snaps that are on the covers. The rivets are the male snaps. Contact your supplier for replacement of the missing items. If you check the installation instructions (above), these are the rivets (below) that are pushed into the holes to be drilled. You should have 16 corresponding female snaps on the covers. Good luck.
White Text Font Metal
awesome thanks then yea im def missing them just open everything and nothing in box. will have to call them on monday lol sucks shoulda check here earlier
Since I saved so much in labor by installing most of stuff myself and buying parts online compare to dealers I went ahead and shop around labor in dealers. Put in order for wireless charger install $99 and $109 for this cargo side panel.
didn’t wanted to risk and just paid it to have peace of mind.
4610
4611
Those plastic things pop off way too easily. That and the ribbed portions are my big complaints about these protective covers.
I'm wondering if WeatherTech has something for this that attaches better.
with the wireless charger do you use carplay or android auto?
Is that a dongle plugged in to the usb that connects it?
Hello no I don’t use CarPlay for two reasons
1: as I have touring with onboard navi and just use that for Navi.
2: don’t want to get into any of that Info issues some people are having were things start messing up as far I saw most were using CarPlay or android auto so I’m just try avoid it by not plugging in my phone lol.
It just usb stick with music in it.
Think you can risk with this , supposedly this should turn into an wireless CarPlay.
I know there are some adapters that work on some models from various car makers, but I think I'll save my $150 and keep it plugged in like it is.
I have had 4 Honda vehicles with Carplay and it works great in all of them, my 2016 Civic EX sedan, my 2017 Civic EX Hatch, 2019 EX CRV traded in for Passport.
I know some have had issues with the infotainment systems, mine in all my various vehicle worked 99.9% of the time and when it went wonky a battery reset normally fixed it.
I spend a lot of time in my vehicles so things have to work. I usually drive 35,000- 40000 miles a year.
Good luck.
Where do you find the hardware? Mine came with nothing.
Just got a used 2019 Pilot and ordered these and the seat backs. These installation guides are perfect! Thanks!
Reactions: DudeCS
Good luck.
I was missing the rivets for the back seat covers but had them for the side protectors. I just went and bought $40 worth of Velcro - cut them into strips and it works perfect. I’ve tested durability by driving with all windows down and such and still holding strong!
2021 EX-L AWD Lunar Silver Metallic
Hi Dude CS- Just a quick note of thanks for the great writeup and pdfs! Also- your companion post for the Rear Seat Protector installation was equally as helpful! I did use the Rotabroach cutters and a 3/16th (3mm) drill bit with a stop collar for the pilot holes- found the job fun and straightforward.
12223
Discussion Starter · #17 ·
You are welcome! Great to have made other's life easier.
Fact? Fiction? ¯\_(ツ)_/¯
Rhubarbpie -
That is the emergency manual release for the fuel door, not the liftgate.
And the side covers do simply snap off.
12303
Great name, by the way. 🐼 love rhubard strawberry pie :love:
Reactions: DudeCS
Rhubarbpie -
Um.... OHHHH! That's why my fuel door was open. Thanks for the quick response. It's always suspect when I think I've discovered something that was missed by everyone else, because usually it's me that's missing something! 🤦‍♂️
1 - 20 of 20 Posts
