Collating information for those interested in a DIY engine oil and engine oil filter change on the 2019 Passport. It will be a while before I'm ready for service.
See PDF attachment below for the two page excerpt from the 2019 Passport Owner's Manual. This is different from the 2019 Passport Owner's Guide.
Other pertinent information as follows:
Please advise if there are any corrections required. Happy wrenching!
- Supplies...
- Engine Oil Filter Element: 15400-PLM-A02 or equivalent (same as most other Honda vehicles)
- Engine Oil Drain Plug Washer (14mm)... CORRECTED part number is 94109-14000 (14mm). It is the same size washer for all current generations of Honda vehicles. One size fits all.
You can buy it by the boat load on Amazon. Approximate dimensions per Q&A:
- 14.32mm, 0.564" I.D ... I verified this dimension.
- 21.76mm, 08565" O.D.
- Engine Oil: 6 quarts of 0W-20 (recommended)
- Tools...
- oil filter wrench (such as, 3/8" ratchet & engine oil filter wrench 07AAA-PLCA100 )
- 17mm socket & 1/2" ratchet for drain plug removal/install
- torque wrench, as needed
- Engine Oil Filter Torque: 12Nm / 8.7ft-lb (from an Accord factory service manual, see below)
- Engine Oil Drain Plug Torque: 39Nm / 29ft-lb (from User's Manual)
- Engine Oil Change Capacity: 5.7 US qt oil (from User's Manual)
The Owner's Manual is not clear on the location of the Engine Drain Plug. It is located on the right side and pointing towards the rear of the vehicle. The photo is taken from behind the front-right wheel and perhaps the best access.
The engine oil filter (blue canister) is located inboard of the front-right wheel (first photo). It is visible through the wheel spokes with a light. It is accessible from behind the front-right wheel. Alternative is to remove the wheel for unobstructed access. There is a frame member below the engine oil filter, so a deflector or cardboard may help to prevent oil from dripping on the frame member and creating a mess.
Reset of Maintenance Minder.
