The plastic engine cover that sits on top of the plastic valve cover can easily be removed. The engine cover if you pop the hood and take a look, Has the Earth Dreams Logo on it. Pull up evenly on that cover and the cover will "Pop" out of the tabs its pressed into. I believe its 4 tabs with rubber grommets that hold the cover in place. Once the engine cover is removed you have more access to placing the jumper cables on the vehicle. The large intake snorkel is still in the way a bit, at least for me. But thats how youd access the battery for jumping the vehicle.
