1 - 20 of 40 Posts
Does anyone have experience with caliper covers? I cannot go with the paint option due to driving conditions. A neighbor uses MGP covers and loves them. Talked to a company to install and they said they no longer carry them because more often than not they cause a squeal. (Various brands.)
3327
My Honda shop did not recommend covers.
What driving conditions are you enduring?
Reactions: CHEFERMAN65
I installed the calipercovers.com on our CRV. Can't imagine why they would cause a squeal, I've never heard one. Can't imagine why a shop would recommend against covers, unless they want to sell/install aftermarket calipers/brakes for big bucks. 10 seconds using a California Duster keeps the wheels and covers looking great.
5394
Read Only
There is a lot of discussion on the various car forums about caliper covers. One oft mentioned concern is that the covers could hinder the dissipation of heat thereby reducing stoping power, shortening break life and causing rotor warpage. several people have indicated that they chose caliper paint or purchased high quality after market pre painted calipers.
Read Only
I don't like or dislike you. But then I don't even think about you.
The vinyl caliper wraps have no heat dissipation property's what so ever, but due to their thin vinyl makeup they do not particularly hold heat in either.
The expensive Aluminum covers, such as MGP's are reported to have some heat dissipation properties, however most people tend not to want to spend the money on covers such as MGP's. Just because it states it is made from aluminum that does not mean that the type of aluminum used is good at dissipating heat.
For me brakes are all about stopping, not pretty. Thats why I am a fan of EBC Brake Pads or Posi Quiet Brake Pads.
My my, don’t like having your buttons pushed, do you.
I simply responded to the OP’s “Caliper Covers?” thread. Guess I should have asked permission 1st.
I think the covers look great and that’s all that matters to me. They are a perfect fit, superb powder coat finish on 6061-T aluminum. I get compliments almost every time I stop for gas.
2019 Elite
I brought up rotors, questioning if the poster was confusing the two.
Rotors will often show rust (overnight) whereas calipers don't. And if that's what they were referring to then caliper covers wouldn't work (to hide rusty rotors);
so I ask - which looks worse: look at me bright calipers, or subdued?
Natural works for me; YMMV.
1 - 20 of 40 Posts
