The Passport Maintenance Minder likely to indicate A7 or B7 (7=replace brake fluid) much earlier than that. Only actual Honda documentation I can find regarding brake fluid change at a 3-yr/x-mile recommendation is in the Passport Owners Manual, referencing the Maintenance Minder code 7: "If a Maintenance Minder does not appear more than 36 months after the display for item 7 is reset, change the brake fluid every 3 years."3 years or 30,000 miles is what Honda recommends for brake fluid changes.
I'm on my 17th Honda right now and have followed the Maintenance minder recommendations since it was introduced by Honda several years ago. NO problems to date with any of the vehicles. My dealer service advisors used to try and tell my that "Honda Recommends" stuff until I had a little chat with the Service Manager and called him out on the upsell B.S. He had to agree that following the actual Maintenance Minder recommendations satisfied ALL warranty requirements. Now, I don't get those "recommended by Honda" pitches any longer.Sometimes it actually pays to read and follow the directions and maybe even bring them to the attention of the dealership.
It is the same story with B6 coming on my MM after only 10,000 miles or so. I know I need to change the rear differential fluid at 15,000 miles and plan on doing that but I see that B6 code as a preparatory reminder and not necessarily a warning to have the service performed ASAP. Just my opinion.The Passport Maintenance Minder likely to indicate A7 or B7 (7=replace brake fluid) much earlier than that. Only actual Honda documentation I can find regarding brake fluid change at a 3-yr/x-mile recommendation is in the Passport Owners Manual, referencing the Maintenance Minder code 7: "If a Maintenance Minder does not appear more than 36 months after the display for item 7 is reset, change the brake fluid every 3 years."
Question about "A7" service
My maintenance minder is showing "A7" service is due. I'm aware that the "7" means replace brake fluid. Does the dealer actually flush and bleed the brakes, or do they simply pump out the fluid from the brake reservoir and pour in new fluid?www.passportforums.com
You are correct, it is just showing what should be done at next oil change. You will start getting the little orange wrench showing (maintenance required) at 15% oil life remaining. It will appear every time you start the vehicle until you get the maintenance done and reminder reset.It is the same story with B6 coming on my MM after only 10,000 miles or so. I know I need to change the rear differential fluid at 15,000 miles and plan on doing that but I see that B6 code as a preparatory reminder and not necessarily a warning to have the service performed ASAP. Just my opinion.
Proper maintenance on your passport give or take a few miles depending on how you drive and area you live in.
Oil and filter service 5-7,500 miles or annually
Rear differential fluid 15-20k miles or every 2 years
Engine and cabin air filter replacement 15-20k miles or every 2 years
Front differential fluid service 3 years or 30k miles is best
Tranmission fluid 3 years or 30k miles is best. Honda says you can go until 50k though
Brake fluid every 3 years or 30k miles is best. Honda maintence code 7 comes up early on new models, Not needed if under 3 years or 30k imo
Engine coolant 5 years or 60k miles is best
Spark plugs 7 years or 60k miles is best. Honda says 100k or 7 years. Check them at 60k and you will likely see replacement is necessary.
Timing belt and water pump service is 7 years or 100k
If your keeping your car long term, slacking on basic maintenance is silly
Even if you lease, lack of maintenance and denied warranty repairs due to lack of maintenance is becoming very common on Honda and Acura Models
Money money money $189Why does my 2020 passport which has 18,000 miles need the brake fluid changed seems kind of earlier for that
The standard interval that Honda recommends is 3 years or 30,000 miles, whichever comes first. If someone tells you otherwise consider whether or not they're trying to sell you something.So I am sitting in the dealer shop waiting for my headlamp replacement under warranty and I see the attached photo. Never heard that I needed to replace the brake fluid every two years. View attachment 14815
