141 - 149 of 149 Posts
2020 Honda Passport Elite
Curious have you tried to swap the left to the right and vise versa to see if the problem follows the LED? If it does I would call their customer service, I haven't had the need to do so but I've heard they work hard to keep their customers happy. They may send you a new one. Who knows they could say it might have a bad resistor...It worth a try.
That’s a good idea, as I have been sitting here waiting for kids at soccer practice I’ve been running the right turn signal without any issue. Going on 5 min.
I swapped my rear turn signals for the LasFit LED specified on this thread. They look great BUT... My right turn signal if left on begins flashing very fast. Generally i don't think i will have my turn signal on for as long as I have to keep it on to get this to happen but nonetheless, I am wondering if anyone else has had this happen? Thank you for your input.
I remember reading in the instructions that came with mine that if they're left on for a extended time, they'll begin to hyper flash due to excess heat. It said this was more likely to happen in hotter weather. It also said that if that happens to turn off the turn signal to let it cool and it will go back to blinking normally.
I've started with LasFits for all interior and exterior lighting. So far, I've done the dome lights (including cargo area), and reverse lights. The interior lights are definitely bright, and very much to my liking. I haven't been able to actually see my reverse lights yet (is there a trick to getting around it auto-shifting to park?), but I figure I'll get my g/f to hold it in reverse while I take a look. I do see that they're definitely working as they reflect off other vehicles and wall at night.
Reactions: JonThor
2021 Honda Passport Elite, White Diamond Pearl
Beachbum07, here are the Lasfit lights I'm using in my PP Elite. They are excellent quality LEDs and I've been running with them for about 5-6 weeks now and very very pleased with them. There are certainly cheaper ones on the market but I'm a firm believer in you get what you pay for.
7443 7444 CANBUS Error Free LED Turn Signal Light Anti Hyper Flash | Amber Yellow
7440 7441 W21W WY21W CANBUS Anti Hyper Flash LED Turn Signal Lights Blinker Bulbs | Amber Yellow
7443 7440 7444 LED Reverse Backup Light Bulb | Xenon White
T10 194 168 LED Interior + Exterior Light Bulbs Error Free|4-10 Bulbs White
Did you use the 7443 Ambers on the front, 7440 Ambers on the rear turns and the 7443 White for the reverse/backup lights? Could we use the 7440 Ambers on both front and rear turns or do we need the 7443 Ambers that connect up with the DTR lights?
2020 EX-L
I may still have the packaging I’ll check in the morning, I honestly don’t remember off the top of my head
Yes, use your "call a friend" option.
...here are the Lasfit lights I'm using in my PP Elite. They are excellent quality LEDs and I've been running with them for about 5-6 weeks now and very very pleased with them. There are certainly cheaper ones on the market but I'm a firm believer in you get what you pay for.
I just ordered these two items direct from the company. #NeverAmazon
Reactions: Gray_Beard
