41 - 60 of 128 Posts
I just installed the the rear and front blinker led lights from lasfit and they work great.
I was just out looking at the connections. How do you access the driver's side turn signal bulb? I came in to look on YouTube ...
Turn the wheel all the way either way and than unscrew the two lower screws holding the wheel well to the front bumper. Once you remove those screws you just need to pull the wheel well out some and reach in.
Turn the week all the way either way and than unscrew the two lower screws holding the wheel well to the front bumper. Once you remove those screws you just need to pull the wheel well out some and reach in.
Got it. I thought that was the key.
The 7440 are for the front and 7443 for the back I just received them today and hopefully will have them all in tomorrow.
Is there any benefit to using switchback LEDs? I thought the biggest benefit was on older cars that do not have daytime running lights, but LED turn signals are new to me.
No benefit on the passport since the bulbs all do just 1 thing. I don’t know if I switchback bulb would work or not.
I asked because I saw the switchback version in your cart in post #33. I have the non-switchbacks in my cart and wanted to see if I was missing something before placing my order.
Oh true hahaha yeah I didn’t even notice that. I went with what the 2019 passport had listed on the lasfit website.
Moderator
Hi guys, Homer you will love the 7440s if you go that route and just wanted to say Lasfit told me yesterday in an email that they did not have a PP option for any bulbs in their compatibility table so am curious as I also only saw the Ridgeline. Hopefully the 7443s will come soon and I will be done with all of the lights. 😎
I am considering replacing the turn signal incandescent bulbs with 7440A & 7443A LEDs (Lasfit). The benefit I am looking for would be brighter lights when signaling and particularly when using hazard lights. After viewing the videos below, I am putting this upgrade on hold for the time being. I am concerned about the heat dissipation using hazard lights and the impact of the brighter lights on other drivers.
There is a comment on one of the videos saying the heat issue has been fixed with the 2019 versions of the LEDs. I can live with the stock amber bulbs for now.
Moderator
I tested the heat factor on mine and it was fine (5 min of flashing and not hot at all hmmm) I need to run the flashers longer to be sure / Im ok with the brightness as I don’t think it would blind folks and I mostly use the PP during the day and the bitch about the PP that I saw on reviews going in was that their taillights are too small and I have a crazy fast 2 lane rd that I turn from to get home and want to be seen every time/we will see...
Moderator
Quick Update; so I ran the flashers longer (15 minutes and they do get warm to the touch and they never went out of sync and my previous test was flawed as I only touched the housing) I do plan on keeping them and will keep the fronts ordered too...
Anybody need free rear signal led lights for a 2018 & 2019 Accord/I have a set that I ordered for the PP and they do not fit / shoot me an email here with ur addy and I will send? Bulb 7507 PY21W amber with no hyperflash
So the Lasfit 7440 do NOT fit the front blinkers?
