Where did you hear they are "auto-leveling"?
Vertical is side to side(I think). Sounds like Canadian trim may have one up. Haven’t seen that on US modelsFrom the specs on Honda's Canadian website and brochures.
On the owner manual, there's a mention of "automatic headlight adjusting system", which reads as follow:
"Your vehicle is equipped with the automatic
headlight adjusting system that automatically adjusts
the vertical angle of the high/low beam headlights."
Huh! Did I go to the wrong Engineering College? "vertical' adjustment is up/down while "horizontal' is side-to-side.Vertical is side to side(I think). Sounds like Canadian trim may have one up. Haven’t seen that on US models
^this, had a mazda and a Lexus that did thatHorizontal is side to side. Vertical is up and down. My Mazda has horizontal lights that track with the steering wheel. I believe verticals adjust for the vehicle load.
In Chicago it usually means someone is jacking your tires. No lie, they do it at stop lights while your in the carToday I actually saw the light moving down a little when I started the car. I wasn't towing or having anything heavy in the trunk, so not sure why it did move.
As I said in my previous post the Lexus RX350 I had would auto-level the headlights every time it was started. I think it's kind of like a calibration procedure... leveling based in the weight in the car irregardless of whether it changed from the last time you started the car. I'm guessing the Passport's auto leveling headlights work the same way.Today I actually saw the light moving down a little when I started the car. I wasn't towing or having anything heavy in the trunk, so not sure why it did move.
Make sense.As I said in my previous post the Lexus RX350 I had would auto-level the headlights every time it was started. I think it's kind of like a calibration procedure... leveling based in the weight in the car irregardless of whether it changed from the last time you started the car. I'm guessing the Passport's auto leveling headlights work the same way.
