The project is close to complete.
red
white -----sub
brown
light grey -----passenger door tweeter
green
red -------driver door and tweeter
brown
grey --------drivers rear door
blue
pink ------passenger rear door
from my testing all wires listed at the top of each group should be positive.
Just need to clean up the wiring in my somewhat rack.
This is the storage area next to the spare.
I mounted me breaker next to the air box which had a factory nut not being used and worked out perfect for me.
I then ran the power wire near the radiator and to the firewall where a grommet was. that grommet came in behind the HVAC unit on the passenger side footwell.
The factory sub is junk get rid of it!!!! When you do add polyfill in the box helps with the rattle.
I tuned the audio coming from the factory amp which is wild to get it to hondas "good". Need to add some more bass to to drivers door in the upcoming days.
All doors have 3 screws in them and the doors just pop off. honda speaker and wire adaptors work great for our vehicle.
When you are removing the A pilar be very careful the plastic is thin and it will damage easy and the plug thing on the back will break I know first hand.
