1 - 19 of 19 Posts
Still in the discovery phase.
Was wondering about wiring routes, light bar fit, mounting hardware and brands.
Reactions: Werlyb23
I just got a 30" curved light bar from Rough Country off Amazon and I'm planning to inset it into the lower grill. I'll be making my own custom brackets and it will require cutting the louvers. Here's a quick dry fit...
Land vehicle Vehicle Car Headlamp Bumper
Automotive exterior Grille Vehicle Car Bumper
I started looking for ways to get through the fire wall yesterday and so far I haven't found a good solution, it's pretty packed under the dash and I'm hoping to do the least amount of disassembly possible.
I was looking at routing the wires inside the fender and thru the drivers door. There’s seems to be a bit of a gap there. I’ve seen where the welcome lights take a similar path at the bottom of the door.
Good luck. I look fwd to your updates.
If you look at the instructions for the Welcome Lights or Running Board with Lights, there is a cutout with a plug under the driver floor and passenger floor. That is where the wiring comes into the cabin.
Thanks. I am hoping to get something in the upper grill area.
Further, what wheels/rims do you have? Love them!
Last night I took the plunge and cut up my front lower grill. This morning I got the first test mounting complete using the brackets that came with the light bar. I'm happy to have the hole in the car filled up, but my instinct was right, I'm going to need to fabricate new brackets to get the light where I want it. The included brackets sit too low and don't offer enough adjustability.
Land vehicle Vehicle Car Bumper Sport utility vehicle
Land vehicle Vehicle Car Grille Automotive exterior
can u use spacers??to raise the brakets u have?
That would work if I was using the brackets as the manufacturer intended. The brackets are meant to have the mounting tab facing away from the light. This would leave the mounting bolt head exposed. I like the look of flipping the bracket around so the bracket and hardware hide under the light. In this orientation the low profile bracket it too close to the light for adequate adjustability. A spacer would raise the light but I still couldn’t tilt it up enough. It’s not the fault of the design, just my desire to hide as much of the mounting as possible.
Hey David, it looks REALLY cool...!
Reactions: DavidCSmithDP
Looks great but the big question for me is, why do you need a light bar on a Passport? I can understand it is someone lives deep in the country or does a ton of off-road driving but for city driving, what is the purpose?
@Treihing for my purpose, the light bar serves two functions, first... I think it looks cool. Let's be honest, that's the reason for a lot of these modifications.
But I do have a practical purpose in that I do actually get my Passport off-road fairly regularly (I'm heading to Anza Borrego this weekend) and I have a low mounted light bar as a relief light to assist in judging the height of obstacles at night. A rooftop bar or a high grill bar will let you see farther which is intended to help in higher speed situations. I'm not running Baja in the Passport so I'm really looking for supplemental lighting to accentuate rocks that are above my available ground clearance. By mounting the bar this low, rocks that are tall enough to cast a shadow are rocks that I need to be careful of. Headlights are designed to be relatively close to the driver's eye line and can cause rocks to blend into the surroundings, the same can be said for roof mounted bars. These low lights also help with seeing in dust and fog, although amber would be a better color choice for that use. They each serve a different purpose.
And they look cool. ?
And it should be said, using lights like this on road is illegal unless the light is DOT approved and technically I should have a cover on these for on road to avoid a potential ticket.
Looks great! Well fitting.
I checked out the light on Amazon and it doesn’t come with a cover. Are you aware of a cover elsewhere?
How did you finally route your wiring? Switch mounted lower left dash? I see even my Elite has a spare slot there I'm hoping to use. If your light bar has an external relay where did you mount that?
I'm looking to add small, fairly easily removable Rigid 2x2 ditch lights and I have the No-lo Designs light brackets which I can leave on all the time easily enough.
BTW for anyone else I have a second pair of the No-lo Designs brackets I'll sell for $75 including shipping if someone else wants a pair. Not sure how I ordered 2 but didn't return them in time.
These are the lights I have, is a nice, complete kit:
1 - 19 of 19 Posts
