Stock tires:
All Passport trims come equipped with Continental CrossContact LX Sport tires. The difference is only in sizes:
Sport/EX-L come with 245/50-R20 102H
https://www.continentaltire.com/product/crosscontact-lx-sport-24550r20-102h/?
Touring/Elite come with 265/45-R20 108H (108H is unconfirmed at this point but I suspect it's true as it appears to be the cheapest option)
https://www.continentaltire.com/product/crosscontact-lx-sport-26545r20-108h-0/?
Based on TireRack ratings, the Continental CrossContact LX Sport in general are not that bad. They are rated good for dry and wet. They are, however, mediocre on the snow and treadwear is not that great.
I was looking for better performing all season tires with good performance on the snow while trying not to spend money on new rims. I also tried to find alternatives with minimum impact on speedometer.
So, here are what I see to be a good alternatives to stock tires based on these conditions:
Sport/EX-L
Michelin Defender LTX M/S in 255/50-R20 109H - great overall tire, highly praised, good wet and snow traction - this would be my choice.
Also would fit:
BFGoodrich Advantage T/A Sport LT in 245/50-R20 102H - good reviews but not many of them comparing to other
tires
Bridgestone Dueler H/L Alenza Plus in 255/50R20 109V - more expensive because of the higher speed rating (149 mph)
Touring/Elite
Michelin Defender LTX M/S in 265/50-R20 107T - great overall tire, highly praised, good wet and snow traction
Continental TerrainContact A/T in 265/50-R20 107T - a bit more off-road oriented with still good on-road performance
https://www.continentaltire.com/product/terraincontact-26550r20-107t/?
Both above options for Touring/Elite have slightly lower maximum speed (118 mph vs 130 mph for stock tires). But I do not see this being a problem for this vehicle. Both above would be my choice depending on priorities: the first one will likely would give a better gas mileage and the second would give a better off-road performance.
Also would fit:
BFGoodrich Advantage T/A Sport LT in 265/50-R20 111T
Bridgestone Dueler H/L Alenza Plus in 265/50R20 106V
In conclusion: all alternative tires listed above are heavier than stock tires, from about 4 lb (Michelin Defender LTX M/S) and up to 12 lb (Bridgestone Dueler H/L Alenza Plus) per tire.
Sport/EX-L
Also would fit:
tires
Touring/Elite
Also would fit:
