1 - 13 of 13 Posts
They won't work when starting from car. Just push the button that corresponds with your fob.
Yeah there should be driver one and driver two setting but I think it only applies with the key fobs.
They are labeled 1 and 2.
When I turn my car off but stay in and adjust the seat to wait for someone. I get out and go into the store. I come back and unlock the car with my fob and the seat will adjust to my setting. Either when I start the car or unlock the door. Can’t remember.
But my point is that it should auto adjust to whatever key for your using when you start the car from inside.
My wife’s CRV auto adjust as soon as I open the door. And we use her fob so it will auto adjust to her setting and I have to press the bottom with my setting to stop it.
Hope that makes sense 😂
It will adjust the seat to your setting when you start the engine.
If you remote started the car, it will adjust when you press the start button.
Definitely weird! There some other quirky things this car does as well! For example, no matter what I try the side of my left leg from the wheel down to the floor never gets warm! Even with the heat really high. But that's another discussion for another thread!
Yea the floor vents are not very strong on the passport. It’s a known issue.
I think there is a setting in the touchscreen for the automatically adjust the seats function. It’s in there.
I think it’s called Seat Position Movement at Entry/Exit under Driving Position Setup menu under Vehicle. Turn that and Memory Position Link on.
2023 TRAILSPORT SONIC GREY
I thought I was just not used to my new settings but I think mine does not auto adjust as well
My Ridgeline would move way back when you turned the car off and stay there until you started it
great for getting in and out easily
Will check my menus
Double checked mine today - It adjusts as soon as I start the engine - which is what I want
1 - 13 of 13 Posts
