1 - 5 of 5 Posts
I found this piece (72862-TG7-A01) on the 2nd row seats. Most likely the tint shop forgot to to put it back in.
Vehicle Grey Personal luxury car Automotive design Motor vehicle
How easy would it be to DIY re-install?
Youtube shows how to remove the door panel but I don't see any videos or instructions on where this barrier goes. The best info I see is the door assembly diagram in various Honda parts store. But I'm still unclear on how to put it back. The youtube videos show a white panel/covering after the interior black panel removal. I was hoping to see the black barrier part.
Thank you.
Its super easy. There are videos on youtube how to remove door panels . I did this on both our 2021's to install new speakers. Takes about 20 minutes from start to finish. Sorry i dont have actual youtube site but do a search on the site.
Here is the video for the front which is pretty similar -
Also pictures of the panel and screws you need to remove for the rear door (under the door grab handle and behind door opening handle). Can use a small flat head or panel opening tool to take them off. Once the 3 screws are off, you can just pull the door off and that foam piece just goes in like a grommet on the door. There should be a spot with that exact shape to install it in.
Automotive tire Automotive design Motor vehicle Tire Automotive exterior
1 - 5 of 5 Posts
