Where did you order them lug nuts? ThanksReceived the new lug nuts today. From 2" to 1.5" in length =
When the tires and wheels were rebalanced, was it on a "Hunter Road Force Balancer" with the full diagnostics? That would help eliminate problems with either the tire or wheel.What I can say at this time is there is a very, very slight vibration above 70mph that you can feel in the steering wheel. Not sure if it's the wheels or the tires. I had the wheels balanced a second time and one of the tires remounted. At speeds, say 40mph, it's smooth as silk but freeway speeds you can notice it. Also not sure if it's the 275 width or the fact you cannot adjust the rear alignment - or both. I do not mean to say it's not driveable, it is, but knowing how smooth it feels at 40mph you do notice it's not the same at 70. The service department at the Honda dealership is pretty good so I may have them check things out and possibly even have them balance the wheels. If it smooths it out at highway speeds the extra cost will be worth it. The set-up was purchased, mounted, and installed by my local Discount Tire shop.
Overall though I am REALLY digging the look of this new set-up.
Thinking of getting these. Or the General AT3 275/45r20. The OEM tires no bueno🤦🏽♂️What I can say at this time is there is a very, very slight vibration above 70mph that you can feel in the steering wheel. Not sure if it's the wheels or the tires. I had the wheels balanced a second time and one of the tires remounted. At speeds, say 40mph, it's smooth as silk but freeway speeds you can notice it. Also not sure if it's the 275 width or the fact you cannot adjust the rear alignment - or both. I do not mean to say it's not driveable, it is, but knowing how smooth it feels at 40mph you do notice it's not the same at 70. The service department at the Honda dealership is pretty good so I may have them check things out and possibly even have them balance the wheels. If it smooths it out at highway speeds the extra cost will be worth it. The set-up was purchased, mounted, and installed by my local Discount Tire shop.
Yes, did this during the second visit. Had them rebalance the fronts and swapped sides. This greatly improved (diminished) the feeling. After a few days I did notice some vibration in the seat so back to have them rebalance the rears. This improved it even more but I may be now hyper-sensitive for the feeling in the steering wheel.You should rotate the tires and see if the vibration changes. It could just be the front tires .
That is what they (Discount Tire) have, not sure about full diagnostics.When the tires and wheels were rebalanced, was it on a "Hunter Road Force Balancer" with the full diagnostics? That would help eliminate problems with either the tire or wheel.
It's always pleasant to see this headline worthy car. Where you able to fix the vibration issue?Been some time since any "build" posts by me so this is only to say I slapped on the roof basket with the new wheels/tires. I have seen a drop in MPG by 1 to 1.5. Oh well.
Almost at 40,000 miles.![]()
Thank you. And yes, as miles have been put on the tires the vibration has disappeared.It's always pleasant to see this headline worthy car. Where you able to fix the vibration issue?
Hey! I am loving your set up! We just got a passport and were looking for a roof basket. Which one is this?Been some time since any "build" posts by me so this is only to say I slapped on the roof basket with the new wheels/tires. I have seen a drop in MPG by 1 to 1.5. Oh well.
Con-Ferr went out of business YEARS ago.Check out Con-Ferr roof racks, I’ve always liked those the best.
Not sure if they’re still in business, do an image search and I noticed some forums selling used ones for $250
In that case you can get a Yakima load warrior or mega warrior.
