One thing to keep in mind is Honda changed from non ferrous aluminum to ferrous metal hoods a few model years back. So the struts might have a hard time holding the hood up. Also servicing/access under the hood will be difficult. No longer able to lock rod in 2nd position.Thanks! One thing I may do is find a hood strut retrofit kit if they're available. Not a fan of prop rods and the hood is a bit heavy.
Our neighbor's '18.Is that a CRV behind the Passport?
Thanks. Yeah, I forgot about that second prop position. I'll just leave it alone.One thing to keep in mind is Honda changed from non ferrous aluminum to ferrous metal hoods a few model years back. So the struts might have a hard time holding the hood up. Also servicing/access under the hood will be difficult. No longer able to lock rod in 2nd position.
