Hello All,
I’ve read through other threads on speaker replacement but haven’t seen (or missed) a definitive answer on whether the stock touring amp is acting as a crossover for the front door/pillar speakers. I have a set of Infinity 6530cx’s and to keep things simple would like to not use the included crossover. Can I install the replacements directly or should I connect them to the crossover?
In addition to adding complexity to the system, I’m concerned that using the crossover would collapse what are now two channels on the existing setup to one channel. At least I’m assuming that’s what the amp is doing as the system is able to send tone to the speakers individually during the test mode sequence.
Thanks in advance!
-Wes
Thanks in advance!
-Wes
