1 - 11 of 11 Posts
2019 Passport Sport
Has anyone put the newer Ridgeline wheels with different offset on their PP ?
Any issues ?
Yes. 2021 Ridgeline 18" wheels with 45mm offset on mine. The lesser offset looks way better, no issues at all. The change in offset from the OEM Passport 20" wheels with 55mm offset is only 10mm (3/8").
'21 EX-L AWD 18" Ridgeline Wheels, 265/60 Cooper AT3 4S, Curt Hitch, Dashcam
Don't know the offset, but these 18's are off of a newer Ridgeline with 265/60's.
**Edit. Didn't realize 21 Ridgeline's offset went from 55 to 45 offset. I don't know if these are off of a '21 or earlier.
Tire Wheel Car Vehicle Plant
Those are pre-'21 with +55mm offset. You can verify the next time the wheels are off. Offset is stamped on the inside of one spoke.
+45 offset makes for a better stance and it’s how Honda should have rolled the passport off the assembly lines. No issue w brake clearance or rub, lock to lock.
Looks good. What tires & size did you go with?
These are 265/60 Cooper AT3 4s's with the 55mm offset for reference. Thinking about going with some aftermarket wheels in the spring. Anyone have issues with 265/60's on +/- 40-45 offset's?
Grille Vehicle Automotive lighting Automotive tire Tire
Gonna bump this thread because I have the same question as Cohocarl - "Anyone have issues with 265/60's on +/- 40-45 offset's? "
1 - 11 of 11 Posts
