Hello,
I've been hunting for a cell phone based remote start setup for a 2021 EXL. The local stereo store wants $700 and isn't interested in sharing the part numbers. I'm curious if anyone that has done a setup could share the parts required. Hoping for a T-harness and everything.
Thanks in advance.
EDIT: Crutchfield provided me the parts required. Read on to learn more.
Parts Required:
iDatastart CMHCXA0 - Remote start "computer"
Firstech Drone X1-MAX-LTE - Cell phone remote start addition
iDatastart ADS-THR-HA10 - Passport Specific T-Harness
The drone comes with an AT&T sim card, they have a Verizon sim card available from the following:
Firstech X1-VZW-SIM
Lastly, Crutchfield said you have to call iDatastart to flash your CMHCXA0 once it is installed. They aren't open on the weekend. I will update once the parts come and I install.
Install:
Instructions: Here
Overview - Its super easy. No splicing, no running cables. The instructions read like you need to wire up parking lights, the ignition lock and a hood sensor. This isn't necessary and those seem to be things for cars without CANBUS connections to these things. Test drive went well and everything works as it should.
Glovebox removal is required. I found this video which provided an idea, he even shows the module you're after:
(135) 2016 to 2018 Honda Pilot Glove Box Removal - YouTube
Then you just plug it all in, activate everything, verify it is working and button everything up.
YOU DO NOT HAVE TO CALL iDatastart if you use their online applications and portal.
The hardest part is removing the glovebox.
Thanks in advance.
Parts Required:
Firstech X1-VZW-SIM
Install:
Instructions: Here
