1 - 10 of 10 Posts
So I am considering a ordering 2020 Passport which will have one of its jobs towing a 3000 lb trailer. I have seen some pros and cons on this forum for using this vehicle for this via the search feature. So if I get Adventure Package B which has the hitch along with AWD do I need to order the oil cooler separately? I also have noticed the vehicle has a fairly low payload, is that going to give problems on tongue weight?
I personally would not purchase this vehicle if I was routinely towing. I love my passport, but there are much better options. The oil cooler is separate, but can be installed by the dealer during sale. The tongue weight should be around 250-350 pounds depending on how close or far the wheels are from the tongue and how much overhang you have on the trailer. I can't find the payload specs for the passport, but I doubt its less than 350 pounds.
Thanks,
The crew at car and driver liked the Ridgeline for towing their track cars, but I guess it did not propagate down to the PP.
I have heard that at 5000 pounds the Ridgeline's towing capabilities are bottom tier. At 3000-3500 its average. I would keep in mind the Ridgeline also has a 6 Speed Honda Engineered transmission. I don't know if I trust this 9 Spd Auto to be as reliable while towing 3000 pounds routinely. This is 100% my opinion though. Good luck picking a vehicle! Its a competitive market out there and sometimes the cross shops in this category vehicle are like comparing apples to oranges.
Got it. I have a 2013 Explorer that my wife, who is for the car is for, loves to tow with. The idea of having two Ex's kind of makes me cringe.
5000 lbs towing capacity with trans cooler installed but you will have to deal with the transmission making unusual noise on the 7-8 shift at moderate speed (45-55). I currently have a case with National Center for Dispute Settlement re. this issue. An arbiter will hear from myself and a rep from Honda. I am requesting a fix for the problem and that Honda release a service bulletin so that others can have whatever fix Honda comes up with. I also want Hinda to reimburse me for the cost of the Honda Care extended warranty because I bought it because I am concerned about the longevity of the transmission due to the noise at that shift point. BTW- tongue weight max is 500 lbs.
Is a powertrain warranty inclusive in the Honda Care extended warranty, or is it separate?
X
Original Powertrain warranty is 5 years/60,000 miles. Honda Care ext. warranty does cover powertrain according to whatever time and mileage limits were purchased.
I don't think the Passport was really designed to tow much to begin with. Maybe light duty stuff like a jet ski and mounting a bike rack.
2019 Elite
To be honest NO Hondas' are serious about towing. While its' 500# hitch / 5000# pulling is adaquate for many light-weight play toys it won't match a real truck;
(I once Proudly owned an incredible 2011 Ridgeline so I know) - the term Real Truck is fighting words within the Ridgeline community.
But Honda's (when properly loaded) 500#/ 5000 pounds is all that many folks require.
1 - 10 of 10 Posts
